Organize
This module walks through practical ways to stay organized on dropbox.com. You will use sorting, multi-file organize, Quick access, tags, and automation options, each framed around real situations you are likely to encounter.
10 minute read
How to sort Dropbox files and folders
When work gets busy, your Dropbox can fill up with drafts, handoffs, and reference files that are hard to keep straight. Suddenly, simple things, like finding the latest version or cleaning up a folder, take longer than they should. Sorting on dropbox.com lets you change how you look at your files so you can make decisions faster, without changing your folder structure.
Think of sorting as a way to switch lenses. You start from Home, then go to All files or open a specific folder. Your files are shown in columns, and each one helps you focus on something different. For example:
  • Modified: see what changed recently, like updates since yesterday
  • Size: find large files when you need to free up storage
  • Type or Extension: scan only specific kinds of files, such as PDFs or videos
  • Name: quickly check naming consistency before a meeting or handoff
  • Who can access: review sharing at a glance
  • Tags: group and scan files by topic or status
Sorting changes how you view your files, without moving anything. This makes it a safe way to explore your content, focus on recent drafts or starred items, and decide what to keep, archive, or clean up later.
To sort files and folders on dropbox.com:
  1. Log in to dropbox.com.
  2. In the left navigation, click Home.
  3. Click All files in the left sidebar. All your files and folders appear on the main page.
  4. Use the available options:
    • To view files you have accessed recently, click Recents on the main page.
    • To view your starred files and folders, click Starred on the main page.
    • To sort by a specific column, hover over a column header, then click the arrow to choose ascending or descending order. You can also add, remove, or reorder columns from this menu, and rearrange columns by dragging the column name to a new location.
    • To resize columns, hover over the column header, then drag the vertical divider that appears to change the width.
    • To change how items are displayed, click the list icon in the upper right of your file list, then choose Grid, Large grid, List, or Large list view.
Notes:
  • You can sort files and folders using the Name, Modified, Type, and Extension columns.
  • When you sort by Size, only files are included; folders are not sorted by size.
  • If you need folder size information, follow the steps in the Dropbox Help Center article on how to view the size of Dropbox files and folders.
How to use multi-file organize to sort Dropbox files
When a project folder gets crowded, it’s hard to spot patterns. You may have years of drafts, finals, and reference files in one place. Some files share a keyword. Some belong together by date. Some haven’t been accessed in a while. Moving files one by one takes time.
Multi-file organize on dropbox.com lets you organize a large folder in one pass. You pick a filter, like keyword, inactivity, timeframe, or smart move. Dropbox groups the files, then shows you a preview of the changes before anything moves. You can exclude any files you do not want included, then apply the update.
Multi-file organize can be a one-time clean up, or a rule you keep running. In the preview, you can choose to apply the rule every time a file is added to the folder. You can use it in automated and non-automated folders. The filters you see can vary based on your plan and the files in the folder. If you change your mind right after applying, you can undo.
You can use multi-file organize with several types of filters. While this feature is available to all Dropbox users on dropbox.com, the specific options you see depend on your plan:
  • Keyword: Group content that shares specific words in the file name, and move those files into a folder you choose.
  • Inactivity: Group files that have not been opened or edited in a chosen period, which is helpful when you want to archive older content.
  • Timeframe: Group files based on when they were created or uploaded, such as by month, quarter, or year.
  • Smart move: Group files into existing subfolders based on Dropbox recommendations.
  • Custom filters: Sort files by size, extension, or keyword, then move them to a folder. You can click Add rule to apply multiple rules to one destination, or Create new filter to send different groups of files to different folders.
To use multi-file organize on dropbox.com:
  2. Open the folder you want to organize.
  3. Click the gear icon next to the folder name.
  4. Hover your cursor over Organize.
  5. Select Multi-file organize from the menu.
  6. Choose the filter option you want to apply, such as keyword, inactivity, timeframe, smart move, or a custom filter.
    • You can combine different rules to create more tailored filters.
  7. Click Preview to see how the folder will look after organizing.
    • From the preview, clear the check box for any files you do not want included.
    • To keep this behavior for future files, select Apply rule every time a file is added to this folder.
  8. Click Apply to finish.
If you apply a change and then realize you want to reverse it, you can click Undo in the panel that appears at the bottom of the screen after multi-file organize finishes. This is the quickest way to roll back a grouping that did not work the way you expected.
Dropbox | File Management | How to use multi-file organize to sort Dropbox files
Find important files with Quick access and Starred items
When your day is full of context switching, even a well structured Dropbox account can feel far away. You might jump between a few key project folders, a shared finance folder or a couple of documents that you open several times a day. Each time, you scroll or click multiple times to get to your destination, which adds up over the course of a week.
Quick access on dropbox.com gives you a personal “shortcut bar” in the left sidebar, where you can group your most important files and folders into named sections. These sections are private to you, and changing them does not affect anyone else.
Dropbox | File Management | Find important files with Quick access and Starred items
Alternatively, files and folders that you star are automatically collected in a section called Starred in the left sidebar, which you can use for a lightweight way to keep your everyday work close.
Because Quick access works across your entire Dropbox account, you can pull together important files and folders from different projects, teams, and shared folders into one personal view. Starring is also personal, so it doesn’t affect what anyone else sees.
Create a Quick access section
  2. In the left sidebar, find Quick access.
  3. Click + (add icon) next to Quick access.
  4. Enter a name for your section, such as This week, Finance, or In review, then click Create.
Sections in Quick access are private to you. Other people cannot see how you name or arrange your sections. Rearranging items in Quick access does not move or rename the underlying files and folders.
Add files and folders to a Quick access section
  2. In the left sidebar, scroll down to Quick access.
  3. Hover over the section you want to add to, then click + (add icon).
  4. Click Add items.
  5. Choose one or more files or folders from your Dropbox content, then click Choose.
You can also drag and drop files or folders from anywhere in your Dropbox account into a Quick access section. This creates a shortcut in the section, and the original file or folder stays in its existing location.
Move or remove items in Quick access
To move an item from one section to another:
  2. Scroll down to Quick access in the left sidebar.
  3. Hover over the file or folder you want to move, then click more options (the ellipsis).
  4. Click Move to section.
  5. Choose a different section from the dropdown, then click Move.
To remove an item from a section, use more options for that item in Quick access, then select Remove from section. The file or folder stays in its original location in your Dropbox account; only the shortcut is removed.
Star files and folders for easy access
Starring is a quick way to mark files and folders that are important to you. When you star something, it appears in the Starred section under Quick access, and it is starred only for your account, not for anyone else who can access the item.
To star files and folders on dropbox.com:
  2. Hover over the file or folder you want to star, wherever it appears in your Dropbox account.
  3. Click the ellipsis (three dots) and select Star.
    • In grid view, you can also click the star icon next to the file or folder.
  4. To unstar an item, click the star icon again.
This way, you can find starred items from anywhere in Dropbox, whether you’re in a folder, previewing a file, or browsing from Home.
Add tags to files and folders
When you work across many clients, projects, or ideas, even a carefully named folder structure can start to feel crowded. You might keep everything for one client in a single main folder, but still want a way to pull out all invoices, or all research, or everything that is ready to send. Rearranging folders every time your focus changes is slow, and it can make older links or shortcuts harder to trust.
Tags are short labels you can add to files and folders, such as ‘work’, ‘invoice’, or ‘ready_to_send’. They help you group and find related items quickly, without changing your existing folders.
You can add tags to individual files and folders, or apply tags in bulk. Anyone who can view or edit a file or folder can see its tags, and only people with edit access can add or remove them. That means you can keep your own system for organizing work, while still making it understandable to the people you share files with. This feature is available to all Dropbox users on dropbox.com.
To add a tag on dropbox.com:
  2. Hover over the file or folder where you want to add a tag.
  3. Click more options (the ellipsis) next to the item, or click the file to open a preview.
  4. Click File info.
    • If you are in full screen preview, click File, then click Info.
  5. You’ll see # Add a tag in the right-side panel.
  6. Type your tag, then press Enter (Windows) or Return (Mac).
Here are some tag rules to keep in mind:
  • Tags must be fewer than 32 characters.
  • Tags can only contain letters, numbers, and underscores.
  • You can add up to 20 tags to a single file.
You can also add tags to multiple items at once in some layouts, for example when you have several files selected. Availability can depend on your current interface and plan.
To remove a tag from a file on dropbox.com:
  2. Hover over the file where you want to remove a tag.
  3. Click more options (the ellipsis) next to the file or folder.
  4. Click File info.
    • Tags for that file will appear under the file preview in the right sidebar.
  5. Click the X to the right of the tag you’d like to remove.
Search for tagged content
There are several ways to search by tag on dropbox.com:
  • Enter the tag in the search bar in the format #tag_name.
  • Start typing in the search bar, then pick the correct tag from the Tags suggestions.
  • When you preview a file, click a tag in the side panel to see all files associated with that tag.
  • Click the search bar, then select a tag from the Tags section in the dropdown.
Dropbox automation options
Sometimes your work follows a pattern. Maybe clients send you new invoices every Friday, photos from a shoot land in the same upload folder, or recordings from a recurring meeting arrive with long, inconsistent filenames. You know exactly what needs to happen next every time, and you would rather not repeat the same clicks week after week.
On dropbox.com, you can turn those patterns into simple automations. You create an automated folder, then tell Dropbox what to do when new files arrive, such as sort them into subfolders, rename them, add tags, convert them to different formats, unzip them, or add a watermark. These options are available to all Dropbox users on dropbox.com, although some specific actions (such as tagging) require certain paid plans.
Create an automated folder
An automated folder is a regular folder that also runs actions for you in the background when new files are added. It is helpful when the same kinds of files always need the same steps, such as sorting, renaming, or converting.
To set up a new automated folder on dropbox.com:
  2. Click Create folder under the search bar at the top.
    • Or click + New, select Folder, then select Automated folder.
  3. In the dialog, click Settings in the bottom-left corner.
  4. Toggle Automate folder to On.
  5. Enter a name for your folder.
  6. Click Create.
  7. Choose how you want Dropbox to handle incoming files. For example, you can:
    • Sort files into categories.
    • Rename files based on a pattern.
    • Add a tag so you can organize and find files later (available on Dropbox Professional, Standard, Advanced, and Enterprise plans).
    • Convert files to PDFs, image formats, video formats, or audio formats.
    • Unzip compressed files.
    • Add a watermark using text or an image, with a preview on the right so you can see how it looks.
  8. Set up the details for each rule, then click Save. You can add up to five automation rules to a single folder by clicking + (add) next to Add step and choosing extra actions.
Once this is set up, any file you move or upload into that folder will follow the rules you chose.
Dropbox | Automation | Dropbox automation options
How to set up an automation
Add automation to an existing folder
If you already have a folder that you use regularly, you can add rules to it instead of creating a new folder from scratch.
To add automation to an existing folder:
  2. Open the folder where you want to add automation.
  3. Click the settings icon next to the folder name.
  4. Click Organize.
  5. Click Add automation.
  6. Choose the type of automation you want, configure the options, then click Save.
If you see options such as Apply to current files or Include files in all subfolders, you can use them to apply your automation to files that are already in the folder or its subfolders. Some automation types can update existing files in bulk, although there is a limit to how many can be updated at once. You must have edit permission on a folder to add, edit, or delete automations.
How to share an automated folder
Automated folders can be shared the same as any other folder. The folder automation will remain for anyone the folder is shared with. Once an automated folder has been shared with someone, they will see notation that the folder is automated as well as which automation option was selected.
Use automation together with tags
Automations and tags work especially well when you want to stay organized without spending extra time on clean-up. For example, you can:
  • Create an automated folder that adds a specific tag, such as invoices or receipts, to every file that arrives, so you can filter for that work later.
  • Add an automation that sorts files into subfolders by date, while also adding tags for project names or client names.
  • Combine consistent file naming with automated folders, so files arrive with predictable names that sort cleanly by name, date, or other columns.
This kind of setup can be especially helpful if you work on your own or as a freelancer, because Dropbox can take care of the repetitive work in the background while you focus on your actual projects. If you share an automated folder with someone else, the folder will still show as automated for them, and they will see which automation options are in use, although subfolder rules may need to be set again after sharing.
How to move or copy Dropbox files and folders
When you work in Dropbox every day, your files can slowly spread across many folders. You might finish a project and want to move everything into an archive folder, keep a single file in two different project folders, or clean up a shared space that has grown messy over time. In all of these situations, you want to stay in control of where things live, and avoid creating accidental duplicates or breaking links.
Your Dropbox folder on your computer works like any other folder in File Explorer (Windows) or Finder (Mac). You can move and copy files into it using drag and drop or copy and paste. On dropbox.com, you can move and copy files and folders from one place in your account to another. Moving helps you reorganize your structure, and copying helps you reuse content without changing the original.
Below we’ll look at the steps to move and copy files and folders on dropbox.com
Move a file or folder on dropbox.com
When you move something on dropbox.com, it keeps the same version history and sharing settings, and simply appears in a new location in your account.
To move a file or folder on dropbox.com:
  2. Hover over the file or folder you want to move, then click more options (the ellipsis).
  3. Click Move.
  4. Select the folder where you want the item to go. You can also click Create new folder if you want a new destination.
  5. Click Move to confirm.
You can also move several items at once by selecting multiple files or folders, then choosing Move from the toolbar or the more options menu.
Copy files and folders on dropbox.com
Sometimes you want a second copy of something, for example a template document you reuse, or a reference file you want to keep in two different project folders. In that case, you can make a copy instead of moving the original.
To copy a file or folder on dropbox.com:
  2. Hover over the file or folder you want to copy, then click more options (the ellipsis).
  3. Click Copy.
  4. Select the folder where you want to save the copy.
  5. Click Copy again to confirm.
The copy is a separate item. Changes you make to the copy will not affect the original, and vice versa.
How to move files between two Dropbox accounts
If you use more than one Dropbox account, for example a personal account and a second account for client work, you might eventually want to move content from one account into the other. You may be consolidating old projects into a single place, or cleaning up before you close an account.
The simplest way to move files between two Dropbox accounts is to use a shared folder. You share a folder from the first account to the second account, move the content into that shared folder, then move it out again on the second account.
From your first account
Start in the account that currently has the files you want to move.
  1. Log in to dropbox.com with the account that holds the files you want to move.
  2. Create a shared folder, and invite your second Dropbox account by entering its email address.
  3. Move the files you want to transfer into this new shared folder.
  4. Log out of this account.
From your second account
Now switch to the account where you want to keep the files.
  1. Log in to dropbox.com using the email address for your second Dropbox account.
  2. In the left sidebar, click Shared.
  3. Find the folder you just shared, hover over it, and click Join folder.
  4. Open the shared folder, then move the files from that folder into the locations you want in this second account.
Once you move files out of the shared folder in the second account, those files are no longer available from the first account. You can leave the shared folder when you are finished, or keep it as a bridge in case you want to move files between the two accounts again later.
How to rename a file or folder
When you work in the same Dropbox account for a while, file and folder names start to tell a story. You might see “final_final_v3,” old project names that no longer match what you do today, or folders that would be much clearer if they included a date or a client name. Renaming is a simple way to make your content easier to scan and search, especially if you often come back to older work or share links with clients.
You can rename items on dropbox.com, from the mobile app, or from the desktop app. On desktop, you rename files and folders the same way you do in Finder or File Explorer, and Dropbox syncs the new name across your devices. On mobile, open the Dropbox app and use the more options menu next to the file or folder name.
Rename a file or folder on dropbox.com
To rename a file or folder on dropbox.com:
  2. In the left sidebar, click All files, then find the file or folder you want to rename.
    • You can also click Folders in the left navigation bar to locate your file.
  3. Hover over the item and click more options (three dots).
    • In grid view, you may see a vertical ellipsis instead.
  4. Click Rename.
The new name appears across your Dropbox account on dropbox.com, the desktop app, and the mobile app, as long as you are signed in to the same account.
Renaming shared folders
You can rename a shared folder in your account, and the folder will stay shared, and the new name will change in your own Dropbox view. People who already have access to the shared folder will still see the original folder name. Anyone who joins the shared folder after it’s renamed will see the new name. This helps avoid confusion when different people prefer different naming patterns.
If you want a shared folder to have the same new name for everyone, follow the steps in the Dropbox Help Center article on how to rename or move a shared folder for all members.
Naming conventions and restrictions
Dropbox recommends a few simple rules for file and folder names so that everything works smoothly across Windows, Mac, mobile, and the web. Even if your operating system lets you save a name, it can still cause problems when you try to sync or open that file somewhere else, so it helps to follow the official guidelines.
Keep file and folder paths under 260 characters
Dropbox recommends keeping file and folder paths under 260 characters. A file path includes the full location of the item, from the top level of your Dropbox to the file name itself (for example, Dropbox/Clients/2025/Project-name/Deliverables/filename.ext).
Longer paths can cause issues, especially on Windows, even if they sometimes appear to work.
Avoid restricted characters
Some characters are not allowed at all, and some are not recommended because they can cause sync or display issues, especially on Windows.
Always disallowed:
  • / (forward slash)
  • \ (backslash)
Not recommended:
  • < (less than)
  • > (greater than)
  • : (colon)
  • " (double quote)
  • | (vertical bar or pipe)
  • ? (question mark)
  • * (asterisk)
  • . (period), with a few exceptions explained below
You can use a period inside a name, but not at the very end of a file or folder name on Windows. For example, project_v2.1 is fine, but a folder called Important stuff. is not.
On the Dropbox desktop app for Windows, items that contain restricted characters can still sync if flexible file names is enabled. In those cases, Dropbox automatically replaces the problematic characters with an underscore on the Windows device, while keeping the original name on dropbox.com.
Do not add a space at the end
Avoid adding a space at the very end of a file or folder name. Trailing spaces can cause issues on some systems and make names harder to read.
Emoji and Unicode support
Dropbox supports a wide range of characters in file and folder names, including emoji, Chinese, Japanese, Korean scripts, and right to left scripts. These names appear the same on dropbox.com, in the desktop app, and in the mobile apps, as long as you stay within the general rules above for length and restricted characters.
This means you can safely use names like 🚀 Project launch .doc or 📚 Budget review.xls to make important files easy to spot, while still keeping them compatible across devices.
In this module, you’ve learned how to sort busy folders, group files with multi file organize, keep key items close with Quick access and Starred, and stay consistent with tags, naming rules, and automations. In the next module, you’ll see how to open, preview, and edit your content, and how to use comments to keep feedback in one place.
